Old 04-23-2009, 10:54 PM
Rick Parker's Avatar
If you do not already have the air horn milled off and the corners raidiused you should, you said it yourself; the air cannot make the sharp turn within the 2" tall air filter anf get down the tall air horn without a lot of problems. A well done 650 DP as pictured below will work fine on you 390 untill you put in a real wild cam or increase the displacement.
[IMG][/IMG]
Rick
