Old 04-24-2009, 04:56 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Default Selling my 428 FE. 400 hp @ wheels.
(UPDATE ON PAGE 2)
Yep, selling my first pride & much joyed 428 FE, for a soon to be pride & enjoyed, 482 aluminum side oilier.
I'm having Keith Craft building me a aluminum 482 side oilier with some where around 625-650 HP/TQ so, I will be selling my 428 FE with 400 HP at the wheels. I have the build spec sheet and chassis dyno information. It will be sold as a long block ( ) minus, the water pump, covers, carb., distributor, wires ect. I think the Vic Jr. intake will be included and has been ceramic coated. I may be buying the Edelbrock RPM with the "ENDURASHINE" to go with my Pentroof valve covers.
Stock stroke-.060 over bore.
Hot Tank Cleaned
Shot Peened
Honed & Plate Honed
Magnafluxed
Sonic Tested
Forged Pistons. 10:3:1
Stock Rods & Crank. (machined)
Balanced Rotating Assembly with Flywheel.
Canton 7qt. racing oil pan.
Carb.- Barry Grant "Mighty Demon" 750 cfm. (annular)
I had Comp Cams grind me a solid flat tappet cam. I have the cam card.
252/260 @ 0.50
600 lift.
110 degree of lobe separation. Very lumpy, great sounding motor and good performing engine. Click on the you tube link below to hear it.
The heads are iron and were ported to the max. I'll see if I can find the flow bench numbers. The valve train are HS rollers that are shaft mounted with all new end stands. I rebuilt the engine in 2004. It is very strong running. I have new stainless pipes & muffler and I'm planning on putting the motor back on the dyno to see if my old one's were restrictive so, the HP/TQ numbers may go up, I'll see.
I sanded the block smooth and painted it my body color. You can scuff it down and paint any color you want.
Polished/Ceramic Coated Edelbrock Vic Jr. Intake.
Polished Intake Breather/Vent.
Polished Edelbrock FE Water Pump.
Polished Edelbrock FE Fuel Pump.
Polished FE Timing Cover.
Polished Pulleys.
Polished/ceramic coated Cobra air cleaner assembly
I have a Tremec 3550 and clutch/flywheel, that could also go with the engine for a decent price. This would be a great combo if your building a cobra or up-grading.
Here's a link of last years "Hot Rod Power Tour" in Kansas. I was feeling ill so I had two of my buddies drive her home. If you have very good stereo speakers on your computer, crank it up.
http://www.youtube.com/watch?v=h3XsqHrtTPY (old pipes)
http://www.youtube.com/watch?v=3fuuIbkJjwI (new stainless pipes)
http://www.motortopia.com/garage/cars/427HISS
Call me for detailed information and we can talk price. As of this moment, I don't have a set price so, serious offers are welcome.
PM me for a phone number.
Thank you.
Regards,
Kevin
