Old 04-26-2009, 04:47 AM
STEPHEN BROHOLM's Avatar
STEPHEN BROHOLM STEPHEN BROHOLM is offline
Cobra Make, Engine: Still dreaming!
G'day sideshow.
Thanks for the info.
I did search under the dash again this afternoon and still couldn't see any flasher/indicator relay-cans.
I pushed the hazard button in again, getting it to produce the typical clicking on/off sounds. I didn't take out the Body Control Module, however I did manage to undo some of the clips keeping the two halves of the BCM case together. I poked my finger inside the BCM and without doubt felt a relay clicking on/off. Could the hazard relay-can be integrated on a PCB within the Body Control Module?
It still appears that the whole assembly needs replacing?
Or could a faulty indicator stalk be causing these issues?
