Old 04-26-2009, 05:42 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
I'm with the guys above about the RotoZip.
There is another tool out there that is used for cutting large holes in sheetmetal. I have one that I used when I installed Air Conditioning in our house, and occasionally since. Works on the same principal as the RotoZip, and uses rotary-cutting bits, but it's heavy duty and set up only for round holes. It's called a Malco HC-1 Hole Cutter. Mine will cut from 2" to 12".
