Old 04-27-2009, 01:15 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Originally Posted by Brent Mills View Post
I figured out what is wrong. If I take my flywheel and place it on the flexplate and align the holes, and then I flip my flywheel now it aligns with what I have (I elongated the hole on my flywheel that was not aligning so that I could see both positions). So, I believe when they made the flywheel, they drilled it with a template reversed. Nice.
Not the first time Ive seen that happen. Probably quite a bit of work involved in your particular case. I would be tempted to try & fit an oversize sleeve in the correct spot once you enlarge the now elongated area, but its your call. Have done a similar trick with Holden six cyl flywheel onto SBF crank. It just happens that they have same bolt pattern, but 'offset' bolt is in wrong direction for the Ford. Motor must be internally balanced? or the balance guy would have spotted it--- seem to remember pics of your build @ KC.
Jac Mac
