Thread: Engine Failure
Old 04-28-2009, 12:51 PM
DAVID GAGNARD's Avatar
90% of the debris in the pan was in the rear of the pan as you can see in the photo. I found the broken rod bolt head end in the pan and one big piece of piston skirt, other than that, there was little debris in the sump part of the pan.....
The stuff you see in this photo is exactly where I found it when I removed the pan and that's after a 7.5 hour drive home with the car on the trailer.
David
DAVID GAGNARD
