Old 04-28-2009, 11:10 PM
maurice19 maurice19 is offline
Cobra Make, Engine: owned Kirkham for 11 years
I don`t know about the 500, but it is a simple matter on the 600.
Order a shortened shaft, remove the long shaft with the trans in a vertical position with the shaft on the bottom have the bearing pressed off the long and onto the short and reinstall the new shaft.
Make sure the splines on the new shaft are as long as on the old shaft, otherwise they will bind up in the clutch because of not enough travel
Maurice
