Old 04-29-2009, 09:26 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Your CAM is pretty close to what I have in my 482 FE (mine is 242/248 @0.050, 112 degree LSA, Lift is .645/.635in). My setup uses speed density mode and idles nicely at about 800 RPM. I was also at the 60% load point in my map at 800 ROM idle. I did use the timming trim feature to help get a smooth idle and my TWM intake has an IAC installed. Do you remember what your VE table setting was at idle in speed-density mode? Mine is at 26. Also, what is your motor's displacement again?
- Fred
