Old 04-29-2009, 11:12 AM
blykins blykins is offline
I'm in the process of changing my 1990 Mustang over to carb.
Yes, EFI is more efficient and it's nice in cold weather....but to me when you can't get a valve cover off without pulling the upper plenum, that's a pain in the butt.
You will need to replace your distributor to one that either works with a current TFI setup, or one that works with an capacitive discharge ignition box. When you eliminate the ECC, your distributor won't know to advance the timing.
For a 302, you can't really do much better than a Weiand Stealth or a Performer RPM. A 600-ish cfm carb will work fine as well.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
