Thread: Engine Failure
Old 04-29-2009, 03:27 PM
Doug I's Avatar
Doug I Doug I is offline
Cobra Make, Engine: Waiting to Order a BDR, engine to be a SA C408. TKO to hook it up.
I thought an accusump kept a volume of oil that it fed back into the engine before you started it. Once the pressure gets over ~25psi it "collects" the volume and then isolates it. When you go 'key-on' it feeds that oil back into the engine to boost the pressure before you hit the starter.
Pull a gear .... drop the hammer .... and enjoy the Drive !!
