Old 04-29-2009, 03:03 PM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
I am in the process of negotiating for a Cobra kit with a 1989 5.0 HO/WC T-5. It has been converted to carb, looks like the only thing that they did was change out the EFI intake system for the Edelbrock Performer intake and the Edelbrock 500CFM 4-barrel. I did speak with the individual who managed the conversion, he said the motor overheated at first b/c they also converted from the serpentine belt system to a V-belt system. That caused the original water pump to rotate in reverse, necessitating a different water pump. No problems since the reverse rotation water pump was installed. It is something you might want to check if you change over.
As for how it runs, IMHO it ran smoothly although it idled a bit high. I think some simple fiddling around with a screwdriver and a timing gun can solve the high idle. We didn't get into any real performance driving that day, just simple neighborhood stuff with a short stint on the freeway to check 70 mph RPM's. I'll be able to tell you more in a week, when I hope to be able to take possession of the car.
If I had to do it myself, I'd opt for the Performer RPM or (better, IMHO) the Air Gap manifold and I'd run a 600 CFM Holley. I'm just more experienced with the Holley than with the Edelbrock. I suspect a cam/lifter swap is in order to get best performance from this current Performer/Edelbrock combo, most certainly if the manifold/carb combo were upgraded to the Performer Plus or Air Gap with the Holley.
Next on the list would be a set of good aluminum heads !
Dugly
YD,E./PNB
No names were changed to protect the innocent!
Last edited by YerDugliness; 04-29-2009 at 03:06 PM.. Reason: original posting contained wrong Performer model
