Eric it can be done with your existing tank. Did this exact thing to a friends SPF. Fab up a 1 gallon surge pot and feed the FI from there with -10. Run the FI return line (probably -8) to the surge tank and then vent the surge to the main tank return (-6). Use a standard electric pump from the main to to the surge tank (-6).
This way the small fuel pump only has to keep up with the fuel that is actually burned and the big pump always has a steady supply.
Works great and you don't have to mod the existing tank.
