Old 05-02-2009, 02:06 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
One suggestion to improve the looks of the safety wire a bit further...start at the spinner, twist the wire toward the target spoke, then wrap the wires around the spoke and finish the final twist inside the spoke, behind the wheel. It takes positioning the target spoke where you can get to it, and laying on the ground at each wheel for a short while, but you end up with the loose end behind the wheel and out of sight where it won't cut or stick you. Then inquiring minds will ask you just how the heck did you do that!!?!
Ken
