Old 05-04-2009, 07:36 AM
Lightbulb Leave it alone, UNLESS
PANAVIA Steve the 2/3 of a quart of oil that is in the lines and cooler will be fine, UNLESS is have cooked the oil. The best thing for you to do is after the oil change is to open the oil filter and look for metal in it. Also check the magnetic drain plug if your motor has one. If no metal is found, change filter and oil. If metal is found, you may want to look in the oil pan pull it down for any more damage. I don't know how hard you drive your car but catching possible damage in the motor will save thousands. Window the block with a rod and you have a 50/50 chance it can be welded. It's alot cheaper to replace bearings, resurface a crank, replace gaskets then to look for a whole replacement unit. JMO Rick L. Ps I do recomend that you overfill the motor 1 quart if you are running a HV oil pump.
