Old 05-05-2009, 08:22 PM
commercialcobb commercialcobb is offline
Cobra Make, Engine: Shell Valley, Ford 429
Originally Posted by bigmike View Post
Commercialcobb:
I empathize with you, I had exactly the same problem with my shell valley. Here's what I found: A. My locker had seized up, allowing no coasting action. Having replaced that it was still pretty squirrly, but not on coast. I blew a u-joint, and while replacing it, discovered 3" of play fore and aft on the rear axle. The rear was turing with the front!
B. When cleaning up to install new bushings, I discovered that no 2 trailing arms were the same length. I ordered 2 long and 2 short adjustable arms from speed way motors, making my rear axle fully adjustable for tracking and pinion angle. It now handles like a dream, as solid as can be. Only took 9 years to get it right!
BigMike
Is there a way to test if the locker has siezed?? Raise it off the ground and turn the wheels or no?? Where did you get the play 3" on the rear axle?? I'lll check my new adjustable trailing arms for lengths and make sure that the axle is square to the frame.. Let me know what you think..
