Old 05-07-2009, 06:03 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
If I might share my .02
The reason for a relay is minimize current throught the switch and to provide maxium voltage to the unit. The switch will be able to handle the current, however over time with out a relay you will be developing more carbon on the contact from the higher current(without a relay). So in the long run your switch will fail mechanically because of the contact but was cause from not using a relay.
