Old 05-07-2009, 09:59 AM
jhv48 jhv48 is offline
It's the tight seal that is causing it to pop off (air pressure that can't escape). Drill a tiny hole either on the side of the lip or in a part of the cap that you can later seal and paint if it bothers you.
I drilled a tiny hole in the black part of the emblem and you can't even see it. Its the size of a pin.
Jim
