Old 05-07-2009, 05:41 PM
kobrabytes kobrabytes is offline
Cobra Make, Engine: KMP532, KC427FE, TWM
Originally Posted by Rwillia4 View Post
After I re-read about it (on page 102 of the manual), I realize it was it dropping below the min RPM (it was right on the edge). Two cut offs that will put you into open loop mode: coolant temp and RPM. There are some other items in there also worth reading.
I agree it is not due to heat at the O2 sensor.
Ye, I don't think you want to be in closed loop at idle. There are too many things that are going on until the engine heats up. I have the idle really solid, although a bit high right now as I keep leaning out the lower left cell to get a better A/F ratio.
What mode do you run in? speed density or Alpha N?
Cobra: A weapon of gas destruction
www.KobraBytes.com
