Old 05-07-2009, 11:36 PM
Cobrabill's Avatar
Cobrabill Cobrabill is offline
Cobra Make, Engine: Superformance 427 Side-Oiler
Originally Posted by Jerry Clayton View Post
Doug
the next time you are at work, you do the walk a round---notice the plumbing used---the braided stuff was WW2----toss the electric pump, and regulator, put on a holley or edelbrock mechanical pump, no regulator and hard line to the carb. Use a short rubber hose from hard line along or inside your frame to the fuel pump inlet on the engine.
the electric pumps are noisy, and create other problems and risk areas---do it like was on oem cars running carbs in the 60s and 70s---make sure your tank is vented
Jerry,really,REALLY bad advice.If you advocate rubber line over braided,you really need to sell your Cobra and drive a VW Beetle.
Electric pumps create NO bad situations.Or risks.Every car in every dealership today has an electric fuel pump.Noisy?You're concerned with a noisy fuel pump on a car that can be heard from two blocks away?
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
