Old 05-09-2009, 12:12 PM
philminotti's Avatar
philminotti philminotti is offline
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
Default PCV valve connection help
Need some help here-
I have Blue Thunder Comp style valve covers and this is the PCV valve:
pcv valve
I would like to connect a rubber hose to it using a right angle connector. I found this at McMaster-Carr. It's a push-to-connect tube connector.
push to connect
However, i'm not sure this can be used with a barbed tube. I believe it is for use with non-barbed tube connections as it has a steel ring inside the connector housing. The steel ring may not fit over the expansion of the barb.
Does anyone have any thoughts or other ideas?
Thanks.
phil
