Old 05-09-2009, 12:59 PM
Ron61's Avatar
Ron61 Ron61 is offline
Post
I did the same thing as mentioned above except I used a Holly Race pump and a regulator to regulate the pressure to the carb. The only drawback I saw to using the set up I had to what Onefastmustang uses is that I put in a return line to take the excess fuel back to the tank and with his pump that matches the needed pressure you wouldn't need the regulator or return line.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
