Old 05-10-2009, 11:43 AM
Scott S's Avatar
Scott S Scott S is offline
Charter Club Cobra Member
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
Default Bump, no inquiries yet make me an offer...
Fully forged, balanced, maged, line honed, and decked 331 Ford assembled with ARP fasteners.
AFR 185 aluminum heads
Ford E 303 hydraulic roller cam
48 IDA Webers matched to this engine by Inglese
Avaid high capacity oil pan
MSD 6AL Ignition
March pulleys
Carter high flow fuel pump with remote canister filter.
Aluminum flywheel with RAM clutch surrounded by a Lakewood steel bell housing.
T-5 transmission with Pro ripper shifter
Ford 9 inch rear end fitted with a 3.73 limited slip gears
4 link rear suspension with QA1 adjustable shocks
Pole Position adjustable upper front control arms with QA1 adjustable shocks
Big Wilwood disks with a Electric High-Power Master cylinder Kit from ABS Power Brakes.
17” Trigo wheels mounted with Toyo Proxes RA 1 tires
Painless wiring
Optima battery with switch
Longacre switch panels with a hidden key switch.
JBL quick release steering wheel
Millenium Gauges
Vintage Air heater
Kirkey drag race seats
Fully carpeted with a headliner
4 point roll bar
Simpson 5 point quick release seat belts
Painted Ford Bright Red with Wimbleton White stripes.
Make me an offer...
Working as hard as I can every day to double my carbon footprint.
