Old 05-12-2009, 06:34 AM
edwhite7 edwhite7 is offline
Cobra Make, Engine: Contemporary, Shelby Alum 427, Dove heads
The dark color of the oil is most likely from assembly lube. I had the same black greasy magnetic stuff on my plug after the first couple of changes. I wouldn't worry to much about that on a new engine. The most likely failure is a bearing and they aren't magnetic. If you see a gold or bronze sheen in the oil then worry. Imagine 24 new rings sliding up and down in 8 new bores for 500 miles, you got to get some wear.
In school 90% is exceptional, in life 10% wrong is failure.
