Old 05-12-2009, 05:51 PM
patrickt patrickt is offline
Originally Posted by maxum_101 View Post
I'm hoping that its not a bearing problem, if it is bearings what am i to see or hear from my engine, what signs, noise? the engine runs great an idels at 800/900 rpm and no noise, oil pres sits at about 40/45 psi at idle...
If you have no noise and 45psi at idle I can assure you your bearings are fine. Bad bearings will drop your oil pressure and create a tell-tale noise that increases with RPM -- it's a whack/rap noise that even if you've never heard it before you'd recognize it as something that shouldn't be there. Do yourself a favor and quit thinking about this -- take your wife out to dinner instead.
