Old 05-12-2009, 10:08 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Originally Posted by NASSTY View Post
When the pic was taken it was being dummied up but the arm that the tensioner bolts to clamps around the snout so its all adjustable. As for 6 ribbed belts, the Yella Terra kit for the quad cams happily uses a 6 rib belt. At 6psi of boost the blower consumes 20hp as per whipple's website.
Al
I think the belt becomes more of an issue at higher boost levels. As the boost goes up the pulley size on the blower gets smaller and the surface area reduces even further.
Keep us posted how it goes together. Looks like an interesting project. Doesn't look like you have an intercooler under there, are you going with water/alcohol injection to reduce detonation or have you dropped your comp?
Mike Murphy
Melbourne Australia
