Old 05-13-2009, 04:17 PM
Three Peaks Three Peaks is offline
Dan,
Are you sure you don't have Mustang II front spindles? My rotors/hubs look just like yours- they measure 1" thick rotor, 1 7/8" high step, then 1 3/4" long bearing nose. These are the GM rotors used on the Mustang II conversions. Mine are drilled for Ford bolt pattern, but the original GM pattern should be the same as the Jag bolt pattern.
Bob
