Old 05-14-2009, 08:17 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default a few more pictures
These are pictures of the street version that is similar to the HCS Coupe except for the dash configuration, proportioning valve, battery cut off, oil temp gauge are not included in the street version, and the lower console panel is also different . Also, the door seal is a bit different as well but I think you will grasp the general feel for the B&B Coupe.
Also, of note because of several modification changes to the nose of the HCS Coupe a couple of the promised performance upgrades have not been completed in time for the show eg: front anti sway bar, adjustable front coil over shocks (we had to resize the shock length and spring weights) and the aluminium plenum. In the last picture the engine compartment is completely different but the general configuration of the firewall will remain the same. Race (and safety) engineered 2" nose bracing have been beefed up to ensure torsional rigidity and overall safety of the car and driver on the HCS Coupe.
Clois
"Let's roll"
"Be part of Something Good
