Old 05-15-2009, 03:47 PM
tcrist tcrist is offline
It should be coated/sealed just like a steel tank.
304SS is the most common used basic stainless steel. It can rust eventually.
316/316L stainless steel should be used on anything that is susceptible to corrosion.
You also have to be sure that the tank is welded with the correct welding rod/wire or the welds will rust.
Terry
