Old 05-16-2009, 07:04 PM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Well after taking care of some honey do's I finally got a chance to look at the Cobra and the first thing I noticed was my distributor cap was completely corrodided with a green chalk. Immediately went to NAPA to get a new distributor cap (MSD cap is the same as an old style GM) but that didn't solve the problem. I borrowed Mat Twiehaus' coil and tried that but not the problem. So I am pretty convienced the MSD 6AL has gone bad. I will take the time to look up the test to see if the box is truely bad. My speed shops here didn't have a 6 AL in stock so I will probably just order one from Summit.
Just a quick question: Should your positive wire on your coil be "hot" when you turn on your key or does it not get it's charge once the car is started?
Clois
"Let's roll"
"Be part of Something Good
