Old 05-17-2009, 07:19 PM
Rick Parker's Avatar
To properly set the pinion depth and correct pinion preload takes some experience. You must have a vast assorment of shims and be able to remove and reinstall bearings and change various shims in an attempt to get the right gear tooth pattern. This requires a hydraulic press, and bearing clam shells, you'll also need a Torque Wrench capable of over 200lbs and a means of holging the pinion flange while tightening it, A BIG VISE. As mentioned above these are not normally in a "Do it Yourselfers Garage." It looks like the engine you are using is capable of generating a lot of torque. A good tip would be to use a machined pinion bearing spacer instead of the collapsable one that is more commonly available. Getting this machined and fit takes a little more time, but is well worth it. I would defer this entire process to someone that has done it often. Being in the Hotbed of Nascar Racing you should have no difficulty locating a shop that can do this, ask around. You may have a shop in your area that does Rear Ends exclusively, or a shop that does a lot of gear work for 4X4's & Jeeps. It is not a real time consuming job if you have the experience and knowledge. This is something you want done correctly.
Pull the axles and remove the gear carrier from the housing and take it to a pro.
Rick
