Old 05-18-2009, 04:35 PM
compaq compaq is offline
Cobra Make, Engine: shell valley 289 with edelbrock perfomer rpm setup.
Default Buying a Cobra Kit Car
Originally Posted by 1ntCobra View Post
compaq,
From your logic then it would make perfect sense in your case to buy a finished used Cobra as the original owner will take the financial loss and then you can enjoy not only the car, but a bargain as well.
Let us know what you end up buying.
Since you mentioned that you are probably right or that basically factors in
because according to this the car is basically new and is drivable and completely finished with paint etc. and other things like the stainless steel sidepipes or they are coated or whatever but since the car has things
that you probably couldn't have for $30,000.00 and it finished and drivable
at this price versus investing another several thousand over the $30,000.00
to arrive at having this then yes it would make more sense to look at it like
that.Even if you do the work yourself you are still probably going to invest
more then $30,000.00 to make the car like this if you just start with a frame and build it up or even what they call a pallet kit.
