Old 05-18-2009, 07:54 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Question?: What type of rear calibers are you using? If GM the pads may not be adjusted out right thus traveling to far for good contact with the rear rotors, giving the brake pedal the same feeling as a poorly bled system. Also not having info on your car-right MC for the type of brakes? Disc/drum, 4 way discs? If you have rear drums-same as above, the back shoes may not be adjusted out far enough. That brings up the proportioning valve. Is it adjusted properly or is this option N/A?
Lot of "if's" involved with 4 qts of brake fluid!
DV
