Thread: Fuel line size
Old 05-21-2009, 03:17 AM
Default Yes it's just fine
tuska Glen that size is just fine for size of the motor unless you are going to spin the motor with a big carb at 7,800 rpms. Is the outlet on the gas tank the same size, and the pickup tube in the gas tank if you are not running a sump pickup system. Running bigger line is fine. You are only going to get as much flow as the smaller tube size in the system. Rick L. Ps Is the hose 10mm or 3/8" in size or where you going with #10 SS hose. There is a big differents.
