Old 05-23-2009, 01:22 AM
efnfast efnfast is offline
Originally Posted by Garage10 View Post
efnfast
When you say foam lance what is that and when using 2 bucket what are you using to wash with ? and when you are done do you apply any wax or sealers ?
Thanks
Brent
foam lance is an attachment to a pressure washer
http://www.everypressurewasher.com/a...sp?sku=CAM1243
basically you put some cleaning foam into it, mix with water, attach to pressure washer and foam the car so it comes out like
Then let sit for 5-10minutes and rinse off.
The purpose of the foam is to help loosen particles for when you mitt wash. Remember, whenever you touch the paint, you're either improving it, or 'damaging' (e.g., marring, swirl, scratch, etc...) it. 90% of damage comes from improper wash technique - dislodging dirt and moving it across the paint to damage it, and drying wrong (using a chamois, waterblade, or anything but distilled (de-ionized water) and/or BLOTTING with microfiber waffle weaves)
So what you're trying to do before you touch it (and you have to touch it to wash it; it's impossible to clean a vehicle, no matter how clean it looks on the surface, without touchign it) is remove as much as possible (initial rinse), then loosen what's left so you have minimal chance for damage.
2 bucket means just that - 2 buckets used in the wash. The first bucket uses a grit guard and has your soap in it. Dunk you mit in, then wash a panel. When that panel is finished, dunk your mitt in the 2nd bucket before going back to the 1st bucket - the point of the second bucket is to accumulate any dirt that gets trapped in the mitt.
I never wax or seal the vehicle unless I'm detailing it. Typically, I'll do 2 details during the year
1 - Very beginning of spring. Claybar the car, correction (compounding) work, polish, seal, wax. The wax I use is mixed with a polycharger additive, so it extends the duration of it. Sealent usually lasts 3-4mths, as does polycharged wax.
2 - Middleish of season - light polish, seal, wax.
I'll usually wash my cars once to twice a month, depending on how dirty they are.
For example, my beater is a black 03 g35 coupe. I'll do #1 at the beginning of spring, wash once a month, then #2 half-way through, then once winter hits I don't touch it from november until april. All the salt, dirt, road **** just stays on it and piles on. Then I do #1 to restore it.
I guarant-damn-tee you my paint is in far better condition, despite being a 7yr old daily beater that has salt and **** sitting on it for 6mths straight with no washing or anything, than 99% of the show cars in this thread that people are fussing over, refusing to wash but sitting there after every drive with their QD wiping it down and 'damaging' the paint.
nb: the below pictures are after I polished it; no sealent or wax applied, or final cleanup.
Originally Posted by STEVE-O View Post
I agree! A pressure washer!?!?
These cars are not driven off road where they would accumulate a lot of dirt. At most, there is only light dust on the car which most of the time doesnt even require water to remove.
If you were going to use water, then I would guess a 'light' flow of water, enough to flush away the dust and then a chamois would suffice.
Follow with a detailing spray like Zaino Z6 or similar product.
No. The point of water is to serve as a lubricant and to also remove dirt.
Unless you zip your car up in an air-tight bubble, you are getting dirt and bonded crap on it, the second you leave your driveway.
