Old 05-23-2009, 03:28 PM
zrayr's Avatar
zrayr zrayr is offline
Cobra Make, Engine: Fords
Originally Posted by Ronbo View Post
...................................Keep in mind your oil clearance is 2~3 thousands of an inch, when you see your oil pressure skyrocket that means it's having a tough time going where it needs to go and your oil pump has to try to force more oil into this high pressure chamber. The end result is snapped distributor pins, ground off gears, and sheared pump drive shafts. (also lots of towing bills)
although these horrible things can happen, they aren't LIKELY to happen if your motor is a good condition, and top quality parts, such as HD oil pump shafts, are used. I'm using a high volume pump & a HD oil pump shaft. I've been using Mobil 1 15w-50 for 24,000 miles at the following (high) pressures:
cold engine:
pressure @ idle: 82 psi
hot engine:
idle (800 rpm) .... 35 psi
1500 rpm ..............70 psi
2000 rpm ..............72 psi
2500 rpm ..............75 psi
3000 rpm ............. 80 psi
3500 rpm ............. 82 psi
4000 rpm ............ 85 psi
5000 rpm ............ 85 psi
6000 rpm ............ 85 psi
6500 rpm ............ 85 psi
I know Texas & New York have little in common weather-wise, but If the use of your engine is moderate to severe, then heavy oil might be indicated if you're not concerned with some horsepower loss.
Z. Ray
'65 K code Mustang
'66 Galaxie 500
