Thread: Brake problem
Old 05-25-2009, 04:57 AM
boris_thespider's Avatar
boris_thespider boris_thespider is offline
Cobra Make, Engine: B&B, 1969 392w, Tremec TKO
Unhappy Brake problem
What is the best way to troubleshoot an air leak? After bleeding each line, the pedal still goes to the floor without much resistance. It seemed like I got all the bubbles out of the bleeders. I blocked off the outlet ports of the master cylinder with plugs and I can't push the pedal down so the master is good. I bent and flared all the lines myself so I'm sure it's my handywork that's causing the problem. I don't see any leaking fluid or bubbles at the connection points. Is there a methodical way of working backwards from the master cylinder to check for problems? Thanks...
Mike
