Old 05-25-2009, 06:11 PM
jwd's Avatar
jwd jwd is offline
Originally Posted by Michael C Henry View Post
I initially had a problem with my clutch master cylinder (7/8") didn't have enough volume. I had to run verry little clutch freeplay to still get adaquet clutch release. I ended going to a larger 15/16" clutch master cylinder.
J
Just curious, what slave cyl. are you using? Wilwood and CNC all require a 3/4" MS in order to have full movement of the slave. Anything larger actually moves the slave too much and you can blow the seal out of them.
Jim
