Old 05-26-2009, 04:42 AM
blykins blykins is offline
Look up in the previous post....3.56 rear with a Toploader.
My Cobra had a big cammed 428 with an aluminum flywheel, a TKO 500, and a 3.70 rear gear. I didn't have nearly as much trouble.
What cam are you running Michael?
Also, on master cylinders, they behave in reverse to how you described. With a larger master cylinder, it takes more pedal effort to actuate the system, but the travel is less. With a small master cylinder, the pedal effort is a lot easier, but you have to push the pedal further to get the same results.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
