Old 05-27-2009, 06:21 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
I had to throw away a Blue Thunder intake manifold because it had a pore inside one of the pushrod holes and was seeping water inside the engine.
I discovered it with the valve cover off and the engine running.
When trying to weld a tube inside the hole the water came out somewhere else, and if I soldered that pore shut the water found some other way out into the engine.
If you have a Dove you may have an aluminum casting defect like I had.
Nothing sounds better than a Cobra in a Tunnel !
