  #57 (permalink)
Old 05-27-2009, 08:58 AM
RodKnock's Avatar
RodKnock RodKnock is offline
Originally Posted by rokndad View Post
Jim, Sorry you are way off on that. The Webers, manifold and linkage, with fuel lines and blocks and synchrometer was $3750 including tax. I think they've gone up a little now but that's what I paid. All the extra parts I needed came from various sources on eBay...some from Italy and some from California. You'd be surprised at how many businesses sell the exact same stuff on eBay they sell through catalogs, and give you about a 30-40% discount.
All my extra jets, e-tubes, 40mm chokes and fuel pressure regulator totalled around $250. That's $4,000 in my book and is no where near the admission price of Dynatek and TWM. A couple thou less??, and that doesn't start to add in the return fuel lines, high output pump(s), high pressure regulator required for EFI. Plus I am told a dyno pull or two or three is mandatory for EFI. I think the EFI setups cost a lot more than Webers. Like others already said on this thread, the Webers worked for me for a lot less without electronic stuff in the engine bay.
Tom (Rokndad) makes everything look easy. He's like a modern day "MacGyver" or.... was it it "MacGruber."
Parts alone for the TWM or Dynatek setup is about $8,000, once you buy all the odds and sods, and as Tom said the Weber setup is approximately $4,000 with some judicious buying. Sometime in the future, I would like to move to one or the other, but it sounds like either approach is not easy to install and tune.
