Old 05-28-2009, 06:37 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
For a single terminal Ford starter, you will need to connect 'B' of Ron's drawing to the starter and 'I' is used to bypass the inline resistor going to the coil. 'I' makes the coil voltage a bit hotter while starting. Once the engine is running, 'I' will have NO voltage to it, so you can NOT use it as a secondary safety feature.
Just a little added information.
