Old 05-29-2009, 07:37 AM
mpanten mpanten is offline
Cobra Make, Engine: SPF #298 427 FI
Originally Posted by CHANMADD View Post
Hello!! Water boils at 100 c or 212 F at sea level, that's the temp that the water "boils off at! Straight science. The pressure will always be a little higher at cooler temps,so one should be aware that you should not "jazz" the throttle when the motor is cold.
I have had a few of these...replaced with a new one every time I overhauled the engine.
http://store.summitracing.com/partde...5&autoview=sku
John
Oil does not need to reach 212 F to drive away the water. If that were the case no vehicle I every owned would last more than 6 months. I have not found anything specific to cars but written anywhere but anything do with aircraft states the minimum is 155 to 165 F. I think it should be a little higher for cars but it does not have to be over 212 degrees.
