Old 05-29-2009, 12:34 PM
Jim Holden's Avatar
Jim Holden Jim Holden is offline
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Rod:
The standard ERAGT brakes are Corvette. Larger brakes can be fitted. The Sierra brakes appear to be the largest that can be fitted and still utilize 15" wheels. A variety of brakes have been used with larger wheels. I do have Corvette rear brakes that incorporate a parking brake.
You would need to decide what size wheels you want to use and Bob P. could then advise as to which brakes would fit. (Actually the Sierras did not fit until Ted ground off some of the "fins" on the caliper.)
There is a car sitting in the shop now where the owner decided, against Bob P's recommendation to use certain brakes. ERA sent the brake folks an upright, but to date, what has been produced does not fit. The bottom line? Having built some 85 ERAGTs, approx 800 ERA427SC and now some 125 ERAFIAs, the boys up in New Britski have pretty much seen it all. You deviate from their recommendations and counsel at your peril.
Jim
