Originally Posted by Rob. Smith
Usually, all the paint goes on in one go...so each coat sticks to the last coat.
(2-pack) I remember, for custom jobs, that with acrylics the colour coat was allowed to dry overnight and sanded smooth to apply the clear coats later. ( acrylic dries to touch fairly fast but the solvents can take up to 30 days to fully evaporate) So if the paint is acrylic lacquer the time difference between coats is a little longer...as long as the painters' clean up and respray techniques are up to the mark there shouldn't be a problem.....Good luck. The paint looks good so far !
Thanks for the info Rob and thanks also to Rebel 1, Craig, Merv and Sharon, Macloft and Mando for your kind thoughts and comments. I think it looks great. Can't wait to get the shiny bits on and the bone Connolly Leather trim installed. Something really different and unique.
I'll post again as soon as the stripes go on. They will be a bit of a bugger to mask up as I have 2 x 5mm stripes on the outside edges, a 50mm wide stripe down the centre with another 2 x 5mm stripes, 5mm either side of the centre stripe, all tapering 25mm wider to the centre of the car from the front and rear. They will be done in special effects metallic silver/grey colour.
Baz
