Old 05-30-2009, 07:29 PM
onefastmustang's Avatar
onefastmustang onefastmustang is offline
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by Seagull81 View Post
Where did you get it and how does it work?
I picked it up off of ebay.. It has a pump and heat canister inside. So it's like a fancy fog machine. It uses 2-3 PSI to push smoke into whatever you are testing. So I hooked it up on my sidepipe with the adapter that comes with it and pressurized the pipe. Smoke started coming out at the four bolt flange so I took it apart and redid the RTV. Leak be gone..
I also hooked it up to my oil dipstick and saw a leak at my fuel pump gasket and fixed it.
Leak be gone..
