Old 05-31-2009, 06:01 AM
Default A spun bearing in the main trying to weld itself to the crank
patrickt A spun bearing in the main trying to weld itself to the crank. At idle it didn't make any noise like you would think.#3 main. The crank just kept spinning. Enough splash from the crank shaft kept it running. This was in a SBC motor. The oil gauge was jumping about 10-15 psi at idle. The rpm was steady. Some motor just don't know when to quit. Rick L
