Old 05-31-2009, 03:09 PM
elmariachi elmariachi is offline
With your geographic location, 100% coolant, and your choice of "enhancer", water pump is indeed suspect as is the size of your radiator (which you have not posted, or posted a picture of).......
Bill S.
Well you are the first guy who has suggested 100% coolant. The radiator is a 2-row 27"X19" with a 22.5" wide x 17.5" high cooling surface. Here's a pic:
I have no idea where Hurricane sourced it, build sheet doesn't give a part #. It does not compare to the SPF or ERA radiators I have seen, the sides are only 3" thick and the finned area is a bit thinner, maybe 2.5-2.75.
