Old 06-01-2009, 07:16 AM
elmariachi elmariachi is offline
Originally Posted by Andrew Teal View Post
I think someone else said how inportant it was to shroud the front also so all the air goes thru the rad. I put on the biggest fan i could get for got how much it flows. The pipes should be coated to cut down on radant heat. Also you really need a oil cooler and a seven qt. oil pan. which cuts down on heat. I run Amsoil oil and there coolant.
I am running ceramic coated headers and pipes and the front is completely shrouded on sides and bottom. I am using an 8 quart Armondo road race pan and though I don;t have an oil cooler, it is not going to solve this problem because a.) the oil is not heating up past the coolant and b.) Having an oil cooler will not help when sitting still (unless I add fans to it too.)
Originally Posted by Eljaro View Post
Are you absolutely sure that P/N 8805 Victor Edelbrock water pump is what you have and is for counterclockwise rotation?
Yes, absolutely positively without any shadow of a doubt, its an 8805.
