Thread: running on
Old 06-01-2009, 08:07 AM
blykins blykins is offline
What's your initial timing set at? You can try giving it a couple more degrees, then turn your idle back down to compensate.
You can also adjust your mixture so that it's a little richer than before. This will sometimes buy you a little bit of lee-way and you can turn the idle speed screw down a little bit to compensate.
Last but not least....does it need to idle that high?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
