  #147 (permalink)
Old 06-01-2009, 10:41 AM
xracerbob's Avatar
xracerbob xracerbob is offline
Cobra Make, Engine: ERA 758 KC Pond 482
Kramer- I had the same tire rub issue on the left front. I took a die grinder and removed just enough of the "lip" to stop the rub. I will be taking it back to the painter to make it look pretty. It rubs at the bottom rear of the wheel opening where the fiberglass lip goes into the wheel well. If the car is up on jackstands, it won't hit. When on the ground turn the wheel all the way to the left and you would see the interference.
